Devo Offline
#1 Posted : Thursday, 12 May 2016 9:14:18 AM(UTC)
Devo
Hi all
Continuing the restoration of my car and i want to bring the engine bay back to original by filling the incorrect holes. Does anyone have good photos of a 69 HT 308/2 speed engine bay primarily inner subframe sides and firewall ?
kevrev Offline
#2 Posted : Monday, 16 May 2016 12:52:06 PM(UTC)
kevrev
Hi Devo here is a photo I've been using as a reference while restoring my car.
Not sure if the photo is 69 or 70, one of the gurus here on the forum might know.
Cheers Kev
Devo Offline
#3 Posted : Saturday, 21 May 2016 6:09:47 PM(UTC)
Devo
Thanks mate that helps a bit. I have too many holes in my inner tubs. I know I need 2 for the drivers side ( washer and headlight loom) but unsure of others.
Ausjacko Offline
#4 Posted : Saturday, 21 May 2016 6:53:12 PM(UTC)
Ausjacko
I have a shot of the engine bay firewall with the holes described if you would like it.
Here goes:
1. Clutch master cylinder
2. Handbrake handle
3. Handbrake cable + rubber boot
4. Wiper motor
5. Speedo cable
6. Red cable from alternator to ammeter
7. Engine wiring plug
8. Accelerator linkage mount
9. Blanked by a 1/4 -20 phillips head screw. Used for 6 cylinder throttle linkage pivot. Refer page 114 of the HT parts catalogue
10. Blanked by a 1/4 -20 phillips head screw. Used for 6 cylinder throttle linkage pivot. Refer page 114 of the HT parts catalogue
11. Heater control cable
12. Interior dash blanket plug
13. Holes above brake booster other end of accelerator linkage
14. ?
15. ?
16. ?
17. ?
18. ?
19. ?
20. ?
21. ?
Happy for others to fill in the blanks.
Jacko
Edited by user Saturday, 21 May 2016 8:15:34 PM(UTC)  | Reason: Not specified
HGV8 Offline
#5 Posted : Sunday, 22 May 2016 7:31:00 PM(UTC)
HGV8
Was thanked: 10 time(s) in 9 post(s)
Cheers Kev
Nice reference photo but is that a HK style heater tap?
Maybe a Holden mockup photo prior to HT 308 release. Noticed it doesn't have master cylinder fitted as yet..
I have a heap of 308 HTG reference photo's if needed.. From cars in recent years, though some are not exactly correct.
Jim
j.williams
Devo Offline
#6 Posted : Monday, 23 May 2016 5:44:36 PM(UTC)
Devo
Good info here . Definately keen to see a few engine bay photos if you can post them
Ausjacko Offline
#7 Posted : Monday, 23 May 2016 5:52:35 PM(UTC)
Ausjacko
OK, have fixed the photo to add 22 as the hole above the brake booster. 13 is as depicted and unidentified
Ian
HGV8 Offline
#8 Posted : Monday, 23 May 2016 6:48:33 PM(UTC)
HGV8
A few Holden V8 engine bays..
j.williams
kevrev Offline
#9 Posted : Tuesday, 24 May 2016 2:26:47 PM(UTC)
kevrev
RHS Skirt and rail
Here's a shot of a NOS HG inner skirt and rail, the only difference with a HT should be an extra hole for the brake fail switch near the brake booster for HG only.
Also the HT has an extra small hole under the washer bottle for a supporting clip.
Cheers Kev
Devo Offline
#10 Posted : Tuesday, 24 May 2016 4:28:43 PM(UTC)
Devo
OK that helps thanks. Looks like 3 holes visible . 2 for the washer tube and 1 down low for fuel line clip.
Plus the washer clip you mention looks like it for the drivers side
Any clear photos out there for the passenger side ???
kevrev Offline
#11 Posted : Tuesday, 24 May 2016 6:53:51 PM(UTC)
kevrev
There's a NOS LHS inner skirt on eBay at the moment, the pictures on the ad might help
http://www.ebay.com.au/i...-HK-HT-HG-/172107164663
gm5735 Offline
#12 Posted : Tuesday, 24 May 2016 9:58:46 PM(UTC)
gm5735
The two pictures below may help.
These are for a Dandenong HT.
#13 Posted : Wednesday, 25 May 2016 8:35:00 AM(UTC)
Here goes:
2. Handbrake handle
4. Wiper motor
5. Speedo cable
14. ?
15. ?
16. ?
17. ?
18. ?
19. ?
20. ?
21. ?
Jacko
Number 3 (if it is the one in the column support) is for mechanical clutch rod (in HT means all manuals other than Saginaw) or rubber boot if hole present and no mechanical clutch mech.
Number 5 is only speedo cable for M21, M22 transmissions or for V8 M35. It is not there for M15, M20, M40 or 6cyl M35 transmissions.
Ausjacko on 1/01/2017(UTC)
Ausjacko Offline
#14 Posted : Wednesday, 25 May 2016 7:50:27 PM(UTC)
Ausjacko
nice, mine is a v8 Saginaw, hence the rubber boot and speedo references. I will update my list.
Devo Offline
#15 Posted : Thursday, 26 May 2016 4:35:24 PM(UTC)
Devo
This is gold guys. Think I'm sorted now
Thanks all.
Ausjacko Offline
#16 Posted : Sunday, 1 January 2017 10:08:46 AM(UTC)
Ausjacko
Bump
Any further views on the firewall holes?
I added a 23 to reflect the correct handbrake cable location down and to the left of 20.
19 is a PO fuel canister add-on.
Devo Offline
#17 Posted : Sunday, 8 April 2018 7:08:54 PM(UTC)
Devo
Hey guys.
I come back to this post to check the engine bay holes etc and being photobucket there all gone......
Can anyone repost the photos that show the factory holes/feedthroughs etc ?
HKM068 Offline
#18 Posted : Thursday, 12 April 2018 12:45:15 PM(UTC)
HKM068
Devo
If you use Google Chrome, there is a fix for the photo issue. Here is link for the add in: https://chrome.google.co...tegory/extensions?hl=en
If not, I have a copy of these photos and can send them to you if you like.
HKM
Devo Offline
#19 Posted : Saturday, 14 April 2018 9:57:14 PM(UTC)
Devo
Thanks for that. Ill do it on my desktop when back at work.
This page was generated in 0.178 seconds.
