Interested to know if any of the parts shown in the following photos are available: First photo - Part 1 - Clips to secure the left and right hand ends of the boot moulding. Haven't found them in Rare spares catalogue? Part 2 - Wiring harness original style bayonet/socket type connectors, if available? Part 3 - Original style Utilux terminal connectors, if available Part 4 - Plastic style wiring harness connectors Second photo - Tramp rod retainer piece - need one only, new or used Third photo - Original style battery terminals Also the original terminals on the wiring harness and battery lead to the starter motor Gerard
Joined: 2/03/2005(UTC) Posts: 451 Was thanked: 15 time(s) in 14 post(s)
You can check out the following Rare Spares parts: BMC1023 is the moulding clip set HK Boot lid. It doesn't have the ends you are after. H1213 is the complete Tramp Rod set, as the factory doesn't supply just components. EC1002 is the wiring terminals that may help. Vintage Wiring Harness in Croydon Vic may be able to help with some of the remaining parts you are looking for.
Thanks for these details, will check the Vintage Wiring Harness for the terminals Gerard
Thanks: 4 times Was thanked: 2 time(s) in 2 post(s)
For any wiring call Aaron at All Auto Recreations on 0418 556 677, he can replicate KTG harnesses. And for repro spring ring battery leads email Andre from ReprosRus, [email protected]. I had a set made up and were top quality.
Joined: 29/07/2006(UTC) Posts: 763 Location: in the shed
Thanks: 8 times Was thanked: 14 time(s) in 13 post(s)
For the boot lid trim I'm using these purchased from USA eBay for $2.20 each they also have a website - www.althafastener.comFits the GTS moulding nicely and comes with mastic sealing washers that squash flat and seal the hole. Speed nuts also have the mastic sealing washers and look as per original. Thread is a bit long so I'll probably cut it to size and then zinc plate them. Edited by user Sunday, 19 June 2016 10:36:55 PM(UTC)
| Reason: Not specified |
"I would never want to be a member of a group whose symbol was a guy nailed to two pieces of wood" (George Carlin) |
