You've missed the point. They stuffed up just like they did the prior year, and found a way to disqualify the car rather than admit they'd showed the flag to the wrong car. I don't know the specifics, I wish I'd quizzed Des when I had the chance, but he did say the supposed oversize valves were the valve stems. In the end they exonerated him but they didn't put him back into the results probably as the times would have showed the mistake. The car's times are erased from the time sheets anyway. They forgot about another car's times though. |
Thanks: 7 times Was thanked: 1 time(s) in 1 post(s)
Hello all.
This thread is so far a great read.
I understand what Byron is not telling us. I also know that if you are patient you will most definitely find out the whole story. I am just as intrigued but I know that I will be patient.
Thanks Byron.....we need to have a beer. |
"HOLDEN MONARO. OUT TO DRIVE YOU WILD!" |
Thanks: 2 times Was thanked: 27 time(s) in 26 post(s)
I first found out about wrong car being shown the flag when I met Des West's god son back in 1998. He told me his god father won Bathurst in 1969. I spoke to Des about this and he claims he won 1969 with Peter Brock.
I then grabbed Bruce in 2000 and put the word onto him about who he was chasing, Des or Colin. He told me Colin, so I left it at that. Maybe I should have been more specific and asked him how many cars were in front of him, because if Des came first and Colin second, he had not actually lied because you have to chase down second place before you can chase down first place.
What I find interesting all these years later is that so many people have "kept quiet" about the truth, if there was such a cover up.
Why did so many go along with it? was there other ramifications, ie loss of cams licences etc? Overall though it shows how little importance was placed upon the race back then, as far as personal results etc. I am sure if Des knew that it was gong to be replayed so many times 30 years and more later he would have ensured that he protested more back then.
Warren
It is amazing Warren that after their error in 1967 (which was rectified after Firth's protest), covered up mistake in 1968, again in 1969 going by Des West they also stuffed up 1970. The Don Holland XU1 that came 3rd was credited finishing a lap down but original time sheets show him on the same lap as Moffat and McPhee. McPhee was directed to "HOLD" to allow Moffat the win as Moffat's car was ailing. Would have been interesting if he'd "held" enough to allow Holland to pass thinking Holland was a lap down. It would have meant an LC XU1 crossed the finish line first. It occurred again in 1976 with the wrong car being shown the flag. Shame Harry never protested in 1969. I'll have to see if I can get Bondy to open up about it as reports say Harry was well aware and Brock knew as well. |
Joined: 6/05/2016(UTC) Posts: 151 Location: SEQld Thanks: 11 times Was thanked: 3 time(s) in 3 post(s)
Thanks Byron.....we need to have a beer. I hear you and you are a Good man being patient ........BUT I AM NOT...I been waiting bloody near 50 years and its TIME to spill their gust and not take it to the bloody grave ....Byron has already said he had a head on and survived thank god... Come on ol" cock ....spill your guts. Edited by user Sunday, 28 August 2016 7:16:54 PM(UTC)
| Reason: typo
You are just going to have to wait, there is much much more to tell on the 81837 vehicles and the race cars that most are not aware of and will blow you away. I'm priveliged to do some proof reading but most of you will have to wait. |
Joined: 16/04/2014(UTC) Posts: 768 Location: Victoria Thanks: 1 times Was thanked: 49 time(s) in 47 post(s)
Ditto. Don't forget, some of this is 25-30 years of one person's passionate work and they will, absolutely correctly, take full credit for it.
What's happening with your Sandman book Byron?
Too hard basket at the moment, still missing too much data. |
Thanks: 13 times Was thanked: 27 time(s) in 25 post(s)
HK1837 just looking back on old post, you mentioned 11 months ago on the topic aussie 327 chev engines about the 327 having the same compression as the HQ308 at 9.0:1 do the yanks rate there compression different to us here in Aus or UK ?
Just thinking maybe if it's true, that's why we have a stupid claim of 9.7:1 for the first XY-A ZD-G 2V 351 Cleveland engines. The USA only made 9.0:1 2V 351 Cleveland's in them years and all our 2V 351C were imported up to mid 1972.
I think they have to be the same, the formula is a simple ratio only. What GM did do though is round up the compression ratio to the nearest 0.25:1. For example the 1967 327 that we got here in the Impala and Parisienne, and also the 2nd type (Canadian) 327 engine in HK both had 75cc heads. Using that data plus the published Engineering technical specs those engines had 8.55:1 compression ratio but they are published as 8.75:1. I got the compression ratio for the 1968 GMH Impala/Parisienne and the 1st type HK 327 as 9:1 from three sources. The first I calculated it as the heads are 69cc. The second is from GM published data of 9:1 for the 1969 327's, which also have 69cc heads. The third is from published data for the combustion chamber ci from 1968 GM Engineering specs for the L73 engine. Why GMH chose to publish the HK 327 and the 1968 Impala/Parisienne 327 engines as 8.75:1 is a mystery, all I can assume is that they used the 1967 data or data that was given to them by GM (note that I still think Flint assembled 1968 L73 327's have 75cc heads and thus published 8.75:1). They got the 307 right, but the 307 was new for 1968 whereas the 327 4BBL for 1968 was as far as GM was concerned the same engine as in 1967 just changed for new stuff for 1968 (like temperature sender in the LH side cylinder head).
Not sure about the Ford Cleveland stuff, but if you dig deeper there may be a good reason for it. Remember the Cleveland was a bit of an orphan in Ford and was dumped from US Fords not long after Bunkie Knudsen left. Most US Ford people believe the Cleveland was very much a copy/paste with changes of the BBC that Knudsen bought with him from Chevrolet. I hear what you are saying though as Ford Australia didn't make any Clevealnd stuff until late in XA so whatever they had in the USA should have been the same here (just like the SBC's). |
I was just looking on Wiki. I know it isn't always the most factual resource, but this page appears pretty comprehensive. It says the 2V 1970 H code 351C was 9.5:1. How do the other specs look compared to the first 2V Clevelands used here? https://en.wikipedia.org/wiki/Ford_335_engine
My Scientific publications XR-XY and ZD book also says 9.5:1 for the 250hp 351C 2V and 11:1 for the 300hp 4V. Edited by user Thursday, 8 September 2016 4:27:50 PM(UTC)
| Reason: Not specified |
Thanks: 7 times Was thanked: 11 time(s) in 11 post(s)
Might've the compression ratio differences between the various 327 engines be to do with using different types of head gaskets...e.g steel shim to composite ? Edited by user Thursday, 8 September 2016 8:22:29 PM(UTC)
No, it is the heads (comb chamber size) |
Originally Posted by: HK1837 I was just looking on Wiki. I know it isn't always the most factual resource, but this page appears pretty comprehensive. It says the 2V 1970 H code 351C was 9.5:1. How do the other specs look compared to the first 2V Clevelands used here? https://en.wikipedia.org/wiki/Ford_335_engine
My Scientific publications XR-XY and ZD book also says 9.5:1 for the 250hp 351C 2V and 11:1 for the 300hp 4V. Yes we get quotes that I have seen from ford Australian on the 351C, the XY 9.7:1 and XA 9.5:1 both USA imported engines, the first has 2V on the heads and the 2ed has 2V dot on the heads, I believe that the dot heads come from engine heads cast from Sep 1970 on and not the falcon model. The mid XA 9.4:1 that is a Aussie built 351 and have seen this in very early P5 LTD and then the 9.1:1 in XB from 1974 and then the 8.9:1 in the XC-D-E for the 2V 351 by Ford Australia. The first 4V 351 imported for our XW GT and most XY GT are 4V heads and clamed as 11.0:1 now Ford Australia claims all 4V 351 were 11.0:1 but that can not be true because when the 4V dot heads came out in late XT and the XA GT they must be 10.7:1 just as the USA 4V claims as they are the same engine, just Ford Australia never pointed it out as such. With the Aussie built 2V 351 Cleveland's we started to cast the heads for such from around May 1973 I believe from what I have been so far to be able too make out and the blocks all came from USA machined up from USA, so all we did was assembled it with our heads and cranks, but then we only had raw cast blocks imported and we them has the ability to machine up the whole of the blocks. So in that I think that the 9.5:1 coming down to the 9.4:1 must be in the Aussie 351 heads. and we first start casting the blocks in Dec 1975 but these are a XE192540 type that we sent to USA. As for the USA 2V 351C I can't find any proof of any 9.5:1 because of the 2V 351W is 9.5:1 and the stupid way Ford does not point out for a fact the difference of a Windsor to a Cleveland, so I can only assume the 2V 351C must be 9.5:1 that is cast from Sep 1969 to Oct 1970 and that from Sep 1970 cast dot heads it become 9.0:1 Edited by user Friday, 9 September 2016 2:12:54 PM(UTC)
