#1 Posted : Tuesday, 30 August 2016 6:36:03 PM(UTC)
Was thanked: 242 time(s) in 216 post(s)
Hi Guys.
One for the Ford gurus.
Can somebody out there tell me where the air cond temperature control sits on the dashboard of an XW/XY GS 6-cyl with factory air.
AFAIK the temp control for XW/XY V8 fits into the same hole as where the choke control would normally sit. With V8s, there is a blank in that spot with a V8 logo, so Ford put it there. For 6-cyl cars (which have a manual choke) the temp control sits below the row of warning lights, so it sits just to the left of the wiper switch, which is normally vacant.
In 6-cyl XW/XY Falcons with a GS pack fitted, the choke hole is already used up & there is no room below the gauges for a control to fit, so where does to sit ?
Silverfox Offline
#2 Posted : Monday, 12 September 2016 7:20:14 AM(UTC)
Silverfox
Terry. I have sent you a msg with a phone number. Cheers. Nick.
#3 Posted : Monday, 12 September 2016 3:29:24 PM(UTC)
Thank you Nick.
Regards, Dr Terry
