LC870 Offline
#1 Posted : Thursday, 9 February 2017 2:47:51 PM(UTC)
LC870
Wanted for a 1970 LC GTR XU-1 Torana .
Looking for a VH 317 brake booster to suit recon or will look at any thing .
Will pay all postage costs if not in Adelaide .
Thank you .
Edited by user Thursday, 9 February 2017 2:50:03 PM(UTC)  | Reason: Not specified
LC870 Offline
#2 Posted : Saturday, 22 April 2017 10:28:06 AM(UTC)
LC870
Still looking for above .
Can any body help ?
#3 Posted : Saturday, 22 April 2017 4:37:32 PM(UTC)
You'll probably struggle top find the exact one you are after, but you can easily build one from other units.
HQ with 4 wheel boosted drum brakes VH316 is identical except for the valve body, VH316 uses VH2031 valve body, VH317 uses VH2030.
HT-HG with front discs VH320 is almost the same, just needs a different pushrod at the back which you can get off an early HK with boosted drums or an early LC with boosted drums, early disc brake one might work too.
A lot of the V8 Torana ones are the same bosster as well with a different pushrod, eg VH229, VH230, VH345. Even some obscure ones like VH333 or 334 of a Ford FG TG Truck or VH332 off an Acco truck are the same basic thing with different pushrod and in some cases a different valve body.
#4 Posted : Saturday, 22 April 2017 6:03:15 PM(UTC)
Give Terry at Hydroboost in Echuca a call. He has lots of bits, and may be able to build you one without needing a core exchange. He knows them inside out, and does a great job.
I have a similar booster on my VL Brock - the HDT strokers got a special booster on them, made from a range of bits.
Terry was able to name all the bits and what they were off - some were from the A9X, and other cars mentioned were XU1 and HT/G. He rebuilt it for me, and it's perfect.
Even though I didn't request it, he even looked after the date code on the housing - being careful with blasting & painting - he's that meticulous.
nineteenfortyeight Offline
#5 Posted : Sunday, 15 September 2019 1:01:32 PM(UTC)
nineteenfortyeight
Hi LC870. Did you ever find a booster for your Torana? I have a VH317 I have been keeping for my HG Van. It needed a rebuild so I took it off and replaced it with a smaller Torana size booster and bracket. I want to put a big booster (disc front) back on it down the track but would prefer a correct early HG one. Let me know?
Ron
48 215
LC870 Offline
#6 Posted : Saturday, 21 September 2019 2:20:55 PM(UTC)
LC870
Hi Ron .
I have sent you a PM .
Thank you .
This page was generated in 0.080 seconds.
