Fastlane
Holden Forums
Holden Technical Talk
hk holden 307 chev 2 barrel rochester carburetor
Hi all. Does anyone have the part number for an original hk holden 307 chev 2 barrel rochester carburetor? More importantly does anyone have one they would part with or know if you can get them new? Thanks
Not exactly where the part number should be, but the one I have here which I think was from a power glide 307 has on the side of the fuel bowl a number which appears to read 703/7/4 in basically an upside down position. There are some unusual marks above the first 7 and the 0. If this is the wrong place to look let me know where else to look for the part number.
Thanks: 2 times Was thanked: 2 time(s) in 2 post(s)
2 BBL Rochester had a small tag under 1 of the screws on the top of the carb. 7027114 D8 ( auto ) on mine. Cheers Baz
Thanks: 1 times Was thanked: 480 time(s) in 458 post(s)
There will be auto and manual carbs for these, and you'll want the right one. |
Thanks guys. Its a powerglide.
That is far easier for you then, as far more 307's in HK-HT were auto than manual. |
Seen a 7027101 C8 manual carby. Was this the one that was fitted to the manuals.
There is heaps for sale cheap in the US too, search for Rochester 2jet. You'd need to find what numbers are on Holden 307 carbs though. I'll look if I still have any to get numbers, I threw a lot out though 10 years ago when I moved. |
Would still be interesting if you could find some other carby numbers HK. Cheers bazza.
Thanks: 4 times Was thanked: 2 time(s) in 2 post(s)
Look up www.rockauto.com and enter 7027114 in the search box. They have them and they're pretty cheap.
sorry to dig up an old post.does anyone know the part number for 2GV manual carb? thanks
Appears as though no one has any idea
Fastlane
Holden Forums
