Fastlane
Holden Forums
Holden Technical Talk
Another dodgy GTS327 engine number
Might be an original engine (can't see the cast date), but a fabricated number. If this is worth that, imagine what a real one is worth! http://www.ebay.com.au/i...c6c0:g:a9oAAOSwtqtZyYlM
Joined: 16/04/2014(UTC) Posts: 768 Location: Victoria Thanks: 1 times Was thanked: 49 time(s) in 47 post(s)
Is it just me, or are there two photos, one with, and one without the middle part of the engine number? Lots of grinding marks too. Wrong spacing, wrong font, wrong number. Other than that, perfect.
And wrong engine plant date code! |
Joined: 28/03/2017(UTC) Posts: 29 Location: Victoria Was thanked: 2 time(s) in 2 post(s)
You guys are too fussy. What do you want for $12,500 |
Monaro HK 327 GTS
Originally Posted by: Monaro23D You guys are too fussy. What do you want for $12,500 Less treachery.
Originally Posted by: gm5735 Is it just me, or are there two photos, one with, and one without the middle part of the engine number? Lots of grinding marks too. Wrong spacing, wrong font, wrong number. Other than that, perfect. One is Photoshopped to obscure the number. Looks like they've used a sander to clean up the number pad. |
Fastlane
Holden Forums
