Joined: 25/12/2015(UTC) Posts: 156 Location: melbourne
hi looking at an engine for sale it is supposed to be a hg 350 manual motor, casting is an 010 block engine number starts with 350 and then the m is stamped about 3mm higher than the rest of the numbers, has anyone else seen this before and should I just give it a miss..
Thanks: 1 times Was thanked: 480 time(s) in 458 post(s)
[img]null[/img] he is going to send me a pic later this arvo.. I had trouble last time trying to work out how to upload a pic, if anyone can walk me through it please.. Edited by user Sunday, 7 January 2018 12:31:44 PM(UTC)
| Reason: Not specified
Joined: 6/05/2016(UTC) Posts: 151 Location: SEQld Thanks: 11 times Was thanked: 3 time(s) in 3 post(s)
Benny...I sent you a PM on how to post a picture...Cheers.
thanks griffo I think I have worked it out, cheers.. Edited by user Sunday, 7 January 2018 12:54:49 PM(UTC)
Joined: 30/04/2005(UTC) Posts: 461 Was thanked: 14 time(s) in 13 post(s)
I don't think a Holden worker stamped that ..... unless he was really drunk at the time ? Mark. |
life is good in "Wine & Holden Marlborough " |
seen some really rough Adelaide 307 and 327,, must of been done on Friday after they went to the pub for lunch..
I have seen some rough ones on the Holden V8's like 253 and 308's...Yeah the guys had a long lunch hour over at the local lol. Edited by user Sunday, 7 January 2018 4:41:48 PM(UTC)
The SBC engines were stamped at the assembly plants, and some were rough as guts. If that is original (and I don't think it is) it is Dandenong assembly plant. I'd need to see the whole number including the engine plant stamp and the date code to know for certain. |
code from engine number is K05 18 H, don't know if this helps
I need to actually see the stampings, and the date code off the side to make a call. If it is what I suspect it is, the digit after the 4 should be a 0, and the date code (side of block) will be something like 1Cxx. If it is that then the roughness of the 350M stamping will make more sense to you. Also find out if it is 2 or 4 bolt. My guess is 2 bolt if it is what I suspect. Edited by user Monday, 8 January 2018 12:50:15 PM(UTC)
| Reason: Not specified |
engine number code.. Edited by user Monday, 8 January 2018 2:18:09 PM(UTC)
It has now appeared on Ebay https://www.ebay.com.au/...=p2047675.c100005.m1851
It is now obvious what it once was. Cast date is either 1B4 or 1E4 which is early 1971 and aligns with the May 1971 assembly date. It will be 350M40xxx. 3rd photos shows it is a 2 bolt. |
so it is a legit engine for a late hg 350
No. Never for a HG, HG 350’s were finished before the end of 1970, and this was cast in April 1971. Plus it is a 2 bolt, HT-HG 350M engines were 4 bolt. The number has clearly been restamped but i’d say it is all the original numbers for the block. However this was never built for a Holden. |
ok thanks, for all the info much appreciated..
