benny Offline
#1 Posted : Sunday, 7 January 2018 10:00:18 AM(UTC)
benny
hi looking at an engine for sale it is supposed to be a hg 350 manual motor, casting is an 010 block engine number starts with 350 and then the m is stamped about 3mm higher than the rest of the numbers, has anyone else seen this before and should I just give it a miss..
HK1837 Online
#2 Posted : Sunday, 7 January 2018 10:25:18 AM(UTC)
Photo required.
benny Offline
#3 Posted : Sunday, 7 January 2018 10:55:55 AM(UTC)
benny
[img]null[/img]he is going to send me a pic later this arvo.. I had trouble last time trying to work out how to upload a pic, if anyone can walk me through it please..
Edited by user Sunday, 7 January 2018 12:31:44 PM(UTC)  | Reason: Not specified
griffo Offline
#4 Posted : Sunday, 7 January 2018 11:32:05 AM(UTC)
griffo
Benny...I sent you a PM on how to post a picture...Cheers.
benny Offline
#5 Posted : Sunday, 7 January 2018 12:36:59 PM(UTC)
benny
thanks griffo I think I have worked it out, cheers..
Edited by user Sunday, 7 January 2018 12:54:49 PM(UTC)  | Reason: Not specified
justgm Offline
#6 Posted : Sunday, 7 January 2018 3:11:03 PM(UTC)
justgm
I don't think a Holden worker stamped that ..... unless he was really drunk at the time ? Mark.
benny Offline
#7 Posted : Sunday, 7 January 2018 3:15:47 PM(UTC)
benny
seen some really rough Adelaide 307 and 327,, must of been done on Friday after they went to the pub for lunch..
griffo Offline
#8 Posted : Sunday, 7 January 2018 4:38:35 PM(UTC)
griffo
I have seen some rough ones on the Holden V8's like 253 and 308's...Yeah the guys had a long lunch hour over at the local lol.
Edited by user Sunday, 7 January 2018 4:41:48 PM(UTC)  | Reason: Not specified
HK1837 Online
#9 Posted : Sunday, 7 January 2018 5:11:35 PM(UTC)
The SBC engines were stamped at the assembly plants, and some were rough as guts. If that is original (and I don't think it is) it is Dandenong assembly plant. I'd need to see the whole number including the engine plant stamp and the date code to know for certain.
benny Offline
#10 Posted : Sunday, 7 January 2018 6:39:13 PM(UTC)
benny
code from engine number is K05 18 H, don't know if this helps
HK1837 Online
#11 Posted : Monday, 8 January 2018 9:37:57 AM(UTC)
I need to actually see the stampings, and the date code off the side to make a call. If it is what I suspect it is, the digit after the 4 should be a 0, and the date code (side of block) will be something like 1Cxx. If it is that then the roughness of the 350M stamping will make more sense to you.
Also find out if it is 2 or 4 bolt. My guess is 2 bolt if it is what I suspect.
Edited by user Monday, 8 January 2018 12:50:15 PM(UTC)  | Reason: Not specified
benny Offline
#12 Posted : Monday, 8 January 2018 2:17:04 PM(UTC)
benny
engine number code..
Edited by user Monday, 8 January 2018 2:18:09 PM(UTC)  | Reason: Not specified
HK1837 Online
#13 Posted : Friday, 12 January 2018 5:56:40 AM(UTC)
It has now appeared on Ebay
https://www.ebay.com.au/...d=p2047675.c100005.m1851
It is now obvious what it once was. Cast date is either 1B4 or 1E4 which is early 1971 and aligns with the May 1971 assembly date. It will be 350M40xxx. 3rd photos shows it is a 2 bolt.
benny Offline
#14 Posted : Friday, 12 January 2018 9:42:22 AM(UTC)
benny
so it is a legit engine for a late hg 350
HK1837 Online
#15 Posted : Friday, 12 January 2018 10:20:10 AM(UTC)
No. Never for a HG, HG 350’s were finished before the end of 1970, and this was cast in April 1971. Plus it is a 2 bolt, HT-HG 350M engines were 4 bolt. The number has clearly been restamped but i’d say it is all the original numbers for the block. However this was never built for a Holden.
benny Offline
#16 Posted : Friday, 12 January 2018 10:51:52 AM(UTC)
benny
ok thanks, for all the info much appreciated..
