Joined: 12/01/2018(UTC) Posts: 2 Location: Sydney Thanks: 3 times
My clock in my Statesman doesn't work. I fiddle with the toggle and it starts up for about 30 seconds and then stops. The car has sat idle for most of its life so I'm wondering if the components are simply dry. Can someone recommend a repairer in Sydney I can take the car to? Thank you
Guessing it’s tuning fork clock like the GTS ones? Does it hum or tick when you start it? It will need new capacitors as a rule of thumb, if it’s a tuning fork/GTS style clock. They dry out and then the clock won’t work. No idea who in Sydney fixes them though sorry. I have got a few GTS clocks working again.
1 user thanked wbute for this useful post.
Joined: 2/02/2009(UTC) Posts: 562 Location: On a build over WWII airfield. Got the .50 cal cases from my driveway to prove it Thanks: 30 times Was thanked: 8 time(s) in 8 post(s)
Dunno if this is of use, but I used a quartz conversion kit in my Buick clock. Is your clock American made? Perhaps the same movement will work? If you're interested I can get the maker's details.
Cheers. Chris |
Attn camry drivers. The accelerator is the skinny pedal on the right. |
1 user thanked Premier 350 for this useful post.
Attilla Instruments, Brendon Dr Nerang on the Gold Coast.
Has repaired a HX, HQ and HZ clocks for me plus other gauges.
All still working
1 user thanked States Man for this useful post.
Originally Posted by: States Man Attilla Instruments, Brendon Dr Nerang on the Gold Coast.
All still working Thank you.....
