Need help identifying the temprature sender in my HX 308 with GTS gauges.
VDO list has the sender as part number 320.003, a button head type sender with a blue insulator, resistive range of 10 to 73 ohms as the correct sender.
Mine is a button head type sender with a pink insulator. Has 125C and W08 stamped on the body of the sender.
Temp gauge is working, not sure if it is accurate.
Thanks in advance
Thanks: 1 times Was thanked: 197 time(s) in 180 post(s)
AFAIK the original Flexdrive brand sender has a pink insulator.
Dr Terry |
