Just a quick question, when was forced air induction first offered in HQ-WB vehicles?
Thanks: 3 times Was thanked: 33 time(s) in 32 post(s)
If you talking about air to the passenger compartment, then from the outset of HQ. Designed with the vents in the door pillars to allow outflow
Thanks: 1 times Was thanked: 197 time(s) in 180 post(s)
Forced air, as defined by GM-H is effectively fan-forced face-level fresh air ventilation. This was first seen in the upper spec models in HJ, e.g. Premier, LS, GTS, Statesmans etc. For HX, Kingswoods gained forced air & by HZ-WB even the most basic models had it fitted as standard equipment. The standard HQ dash vents were not fan-forced, while the the factory air con system would not allow fan-forced air at face-level unless it was air conditioned air. The factory air con in HJ-WB did allow this with that extra position added to the air control level. Dr Terry Edited by user Friday, 20 April 2018 12:15:02 PM(UTC)
| Reason: Not specified |
Thanks Terry. Was sure I read that in your 50 Years book, but I have misplaced it.
Originally Posted by: wbute Thanks Terry. Was sure I read that in your 50 Years book, but I have misplaced it. Buy a 60 Years book, it has more info & is more accurate. Dr Terry |
Just out of interest, when did the heater system first get induction via a blower fan? I remember my Dad's HK had it, but our EH did not.
Originally Posted by: Jul71-Oct74 Just out of interest, when did the heater system first get induction via a blower fan? I remember my Dad's HK had it, but our EH did not. Fan heaters have been around since FX in one form or other. Motorless heaters were made available, usually as a dealer-fitted accessory from FB to HG. Cars earlier than FB didn't have a plenum chamber type air intake to enable the motorless type to operate. In early 71 ADRs made motorised heater-demisters compulsory, so the motorless type disappeared. Premiers had the motorised heater-demisters as standard equipment & these units (minus the centre console) were also available on Specials & Standards etc. However they were quite expensive, so the motorless type were made available as a cheaper alternative. Dr Terry |
