I’m trying to track down a 4 barrel air cleaner for a Holden 308 can any one help
What Holden, Statesman, Commodore or Torana model? Some are different for an aircon car too. There would be probably up to 20 different air cleaners. |
Probably the easiest to find! None on EBay right now. |
Will keep an eye out for you. From memory you want: Snorkel at 3 o’clock, PCV air at 7.30, hot airbox intake on the snorkel plus the valve for it underneath and no choke air intake. Like this but a 5.0L one: http://holdenpaedia.oldh...om/File:HZ_eng_bay_1.JPG |
Ok that would be great thank you
Closest I have seen so far. It is a HJ one though and has the snout cut off. You could get an old 253 base and swap the snouts over (brazing it on would do), and blank off the choke pipe underneath (small tube you can see in photos). Lot of money for a butchered one though. https://www.gumtree.com....premier-vk-vh/1180148500 |
hk1837 I have pmd you but says your full, could you pleas pm me thank you
