Fastlane
Holden Forums
Buy, Swap & Sell - Holden
WANTED - a few HK-|HG bits if anyone has some spare
Thanks: 1 times Was thanked: 480 time(s) in 458 post(s)
Looking for the following bits if anyone has them:
For HT-HG Trimatic console: Mask - Indicator dial Dial - Indicator Support Assembly - Dial. This is to convert a Powerglide console shift insert to a Trimatic one as fitting a TH350. These bits are the clear window with PRND21 on it (rather than PRND1) and the slotted bit below it that the red tongue shows through.
Also looking for the wiring harness off a HK-HG console shift, off any gearbox that works with the T-bar and has the light in it.
Lastly a HK GTS woodgrain insert for a console shift auto insert. The replica ones are nowhere near the right colour and do not match the rest of the dash. |
Joined: 2/11/2017(UTC) Posts: 62 Location: frankston Was thanked: 2 time(s) in 2 post(s)
Hi HK, I have noticed a Trimatic console Centre section with slider etc for sale on Gumtree. The Guys name is Sam, at Bennet Springs WA 6063.His add reads Holden HK HT HG assorted parts for sale. And Premier parts. I hope this helps you out. Be Quick.
Thanks mate. Talk about bad timing, not in Australia right now. |
Joined: 2/03/2005(UTC) Posts: 451 Was thanked: 15 time(s) in 14 post(s)
Private message sent regarding components.
Fastlane
Holden Forums
