smithy Offline
#1 Posted : Sunday, 5 August 2018 5:07:52 PM(UTC)
smithy
Hi
anyone know what's going on with the oil gauge. Shoots to full press when accessories on then when I start engine it slowly falls to zero. Sender seems ok. has an ohms reading.
#2 Posted : Sunday, 5 August 2018 6:08:42 PM(UTC)
Was thanked: 480 time(s) in 458 post(s)
Do you have a 0V strap (negative) "strap" from the battery -ve terminal to the body? Normally to radiator support.
Do the other gauges behave?
It may just be the wrong sender too.
smithy on 5/08/2018(UTC)
smithy Offline
#3 Posted : Sunday, 5 August 2018 8:09:23 PM(UTC)
smithy
Hi
thanks
yes it has the earth strap. Maybe wrong sender? Other gauges work ok. except for fuel.
The oil gauge did not move at all until I swapped the sender out of the HQ 253 which gave me the problem I have now. High read when on accessories and no read when idling.
#4 Posted : Monday, 6 August 2018 6:44:16 AM(UTC)
It is the wrong sender.
HJ have thermal gauges & require sender VDO number 360-005.
The HD-HQ sender will operate exactly as you have described. One thing though is that the gauges should not operate in the accessory position, only with ignition on.
Edited by user Monday, 6 August 2018 6:47:30 AM(UTC)  | Reason: Not specified
smithy on 6/08/2018(UTC)
smithy Offline
#5 Posted : Monday, 6 August 2018 8:21:41 PM(UTC)
smithy
Thanks Heaps
This page was generated in 0.088 seconds.
