Joined: 23/08/2018(UTC) Posts: 33 Location: Perth Thanks: 23 times
Hi all, sure you've probably had this question a few times already. Looking for the correct part number / date code and location of both for the following, in reference to 1971 Sept built 350 HQ Coupe.
Intake manifold Distributor
Thanks for your help
Pretty sure the dizzy is the same as most HK-HG with SBC design engine. 1111150. Specs are the same but for some reason those pre 1973 HQ’s are listed as 11111500 in the HQ service manuals. Could never figure out the exact reason for the number change, I discussed this a bit in the article in one of the Just Holdens back issues. From memory the final HG 350 manual cars with the Canadian engine list the same dizzy but listed as 1111500 (one less 1), but still the same specs. |
Thanks: 11 times Was thanked: 11 time(s) in 9 post(s)
6/71 hq
^^That’s the one. I could never figure out why the number change from 1111150 to 1111500 when the specs didn’t change. The only clue I ever found was that 1111500 was possibly a spare part number in North America for 1111150, and 1111150 ceased being a production distributor by the end of 1969. GMH appeared to have been given 1111500 for the final HG engines and for HQ up to a point where they changed to a later US spec dizzy. |
Cool, thanks for your input guys. So the distributor I'm looking for is 1111500 with date code 1 A,B,C OR D THEN XX. Is that correct, as I understand, most parts for 71 cars were up to around Aprilish.
Intake I think I've worked out as 3973469 K then 1 to 12. With a date code same as distributor?
yes dissy is 1111500
manifold is right 3973469 with K1 to ?
have not found date code on manifold but I will look closer today.
some people are selling K marked manifolds saying the fit HQ's but make sure on the pass/side there is only 2 bolt holes
in the centre were it bolt's to the head, not 4 as the extra 2 holes are for an A/C bracket.THe HQ's only used the head bolts for
this bracket.
Unless total concours is your goal just use one off a 307. Same curves and looks the same, just one less 1 and the extra 0 on the HQ one! Edited by user Saturday, 25 August 2018 2:28:54 PM(UTC)
| Reason: Not specified |
That’s the one, easy to find as common to all HK-HG except the last HG manuals and IIRC the 1968 Impala and Parisienne. Lots in the USA too, off 1968 L73 and there were huge amounts of them made. |
Originally Posted by: HK1837 Unless total concours is your goal just use one off a 307. Same curves and looks the same, just one less 1 and the extra 0 on the HQ one! Hey Byron,Total Concours only way for this car, have not been on here for a long time but you know the car. Just getting back into collecting number and date correct parts and info for it. I will no doubt have more questions. Cheers
this bracket. Thanks for that, did not know about the extra 2 holes. Will keep this in mind.I thought there is a date code on the lower section behind the dizzy and in front of the part number.
Will have a closer look but there is no casting date code it maybe stamped .
Found the date codes one is D 23 1 the other is B 5 1.If you locate a correct manifold check under the heat shield for holes in the exhaust passage.Itcan be repair but costly. Edited by user Monday, 27 August 2018 6:55:07 PM(UTC)
That's Awesome thanks for the tip. Can't beat learning from someone else's experience.
So next piece of the puzzle.... I need a tailshaft. My understanding is they were painted purple and possibly the same as a 1 tonne ute shaft?
Joined: 30/04/2005(UTC) Posts: 462 Was thanked: 14 time(s) in 13 post(s)
Hi , not the same as 1 Tonner , they have 121' wheelbase , wagon/statesman /ute all 114' & sedan & 4 door all 111' . thanks Mark. |
life is good in "Wine & Holden Marlborough " |
yes one tonner uni's and purple but paint is very poor looks like overspray
Thanks guys, so in short, any HQ sedan tailshaft with 1 tonne unis. No difference between 6 and 8 sedan tailshaft, just uni joints?
