Thanks: 1 times Was thanked: 480 time(s) in 458 post(s)
Just asking for a friend.
2006 100 Series V8 ‘cruiser, runs on both LPG and ULP. Gas is a multi-injector setup. Developed a small coolant leak under the valley and started to get warm. Got it home OK but now will not fire on gas of fuel. Has spark. Any suggestions? |
Thanks: 1 times Was thanked: 197 time(s) in 180 post(s)
Check the 12V supply to the injectors. Also check the (petrol) fuel pressure. Even though it has LPG, it always starts on petrol & then switches over.
Dr Terry |
Thanks Terry. I think they are still struggling with it. These things have a “car upside down” relay that cuts off the fuel so it may be that has failed? Will pass on your text to them. |
