Joined: 26/10/2018(UTC) Posts: 3 Location: Queensland Thanks: 5 times
Hi I have no idea about car engines, so please forgive me. I was advised to purchase an engine for a toyota dyna. Which was incorrect and now I wish to sell it. I was informed it is a Holden V8 308 with a VM 660589. The only other number I can find is GM 92062646. It is a 5 litre engine.It also has an auto gearbox. Can anyone please give me any information about this engine. Thanks
Joined: 30/04/2005(UTC) Posts: 462 Was thanked: 14 time(s) in 13 post(s)
Hi , VM was used on 2 Holden V8s VB-VC-VH -VK Red/Blue & black carby motors , But yours should be the 304 EFi motor VM660569 would be late 1997 or early 98 .thanks Mark. |
life is good in "Wine & Holden Marlborough " |
1 user thanked justgm for this useful post.
Thanks: 1 times Was thanked: 197 time(s) in 180 post(s)
I believe it will be an early VT 5-litre with sequential injection. VM in an early Commodore (VB, VC & VH) is not a V8, it is a lo-comp 3.3 6-cyl. If it is complete with all its ancillaries, ECU & harness etc. it would make a good conversion project for an HQ-WB Holden. Dr Terry Edited by user Friday, 26 October 2018 12:13:00 PM(UTC)
| Reason: Not specified |
As Dr Terry says. It could also be newer than VT as well, VS utes continued to use the VM 5.0L until about August-September 2000 whereas VT 5.0L ended mid 1999. The ECU will tell you what its original application was. |
My ute is a 1999 VS SS and its VM 671346 so your 10,777 engines before me. If thats how it works.
1 user thanked panoman for this useful post.
That is exactly how it worked. Given the 10,000 number difference I'd be pretty confident it is from a VT not a VSIII. Edited by user Monday, 29 October 2018 5:44:00 PM(UTC)
| Reason: Removed irrelevant text. |
Thanks to everyone who has replied to this post, I appreciate your assistance. Wal
Where are you and how much do you want for it??
I am in Warwick Queensland and I will take $1600 for the motor and gearbox.
