Joined: 23/12/2017(UTC) Posts: 4 Location: Blacktown Thanks: 4 times
Gday fellas!! i need rust repaired in the lower parts of my passengers rear door, got a few bubbles. Anyone know of someone in West sydney who does this kind of stuff? dropped into a couple of panel shops and they wouldnt even bother having a look, i dont understand???? i will eventually get it re-sprayed but for the time being dont want the rust to get worse.
on a 2nd note, my windscreen is leaking water in fromthe top when i was the car, has anyone had this happen? if so, is it just a windscreen seal or more to it? im hoping its a simple seal fix or something.
CHEERS!!!
Talk to Dr Terry, he may know some decent panel shops around him.
Probably the seal, but it may also have rust under the screen. I had a HJ Belmont sedan that used to drip from the top of the screen in heavy rain. |
Thanks: 1 times Was thanked: 197 time(s) in 180 post(s)
Yeah, most panel shops these days survive on insurance work on modern cars, where the jobs are quick & clean, they just don't like working on older cars.
If you phone me at work, I'll can give you some good contacts who can do older cars.
9644-2888 after 10 A.M.
Dr Terry |
Joined: 2/11/2017(UTC) Posts: 62 Location: frankston Was thanked: 2 time(s) in 2 post(s)
Yes there will probably be some holes around where the seal fits. I's a shame that you don't live in Melbourne as I could do the rust for you. Good Luck.
1 user thanked morsesworld for this useful post.
Thanks for the replies guys, Dr.Terry I'll give you a call when I've got a few minutes to talk.. bit chaotic leading into xmas time.. Cheers moresworld hopefully it's not rust..
