Has anyone seen these available new anywhere? I bought some HQ ones for the HK for the fuel and brake line along the sill (like the below link) https://www.kingswoodcou...3-hq-hj-hx-hz-wb/RC0006
However I think i’m going to go down the Holley Sniper EFI path which needs a return line, so need one of the HJ to WB clip types that have two fuel lines and a brake line (one fuel is vapour line for canister on HJ to WB). Can go chasing used but thought there may be a repro source that I haven’t found as yet. |
Joined: 20/03/2011(UTC) Posts: 132 Was thanked: 16 time(s) in 16 post(s)
If it suits you, commodore VB to VL have a tethering clip that joins two lines together. You could mount the two lines and tether the 3rd line to one of those, looks pretty neat as well.
