SLENUT Offline
#1 Posted : Saturday, 2 March 2019 3:12:29 PM(UTC)
SLENUT
Hello all
I'm looking into fixing my large Salisbury diff, VB sedan, after it went bang many years ago.
I have a spare wagon housing here, I will us the centre and pinion into the sedan housing but I'm unsure on who has the best bearings to use.
I've seen a seller on eBay have listings for LH-LX and HQ-WB, but apparently neither of these can fit a Commodore VB-VK 5 litre
I would like to know a good brand so i can go to my local and order a set in.
Also, how easy is it to obtain a set of 28 spline axle bearings, I'm not sure if its part of the diff bearing kit.
The Commodore SL/E fanatic.
#2 Posted : Saturday, 2 March 2019 8:27:43 PM(UTC)
All bearings on HQ through to VK large Salisbury should be the same, bar the retainer on cab chassis axle bearings.
8D11PCH2 Offline
#3 Posted : Sunday, 3 March 2019 12:11:00 AM(UTC)
8D11PCH2
Was thanked: 23 time(s) in 22 post(s)
Originally Posted by: SLENUT Go to Quoted Post
Hello all
Timken https://www.timken.com/
SKF https://www.skf.com/au/index.html
I believe GMH has used both of these brands in our Holdens and packaged as Genuine replacement parts and I reckon you can't go wrong with either.
FAG is another brand GMH has supplied as spare parts in the past but from memory they were made in Brazil.
