Hey guys. Just rebuilding my crossmember after a strip down and paint. Now I have gone to fit the upper control arm by installing the two bolts attaching the shaft but they bottom out leaving the shaft loose.... Now I may have lost the caster/camber shims but I thought it should be able to tighten up with no shims surely. Have I missed something or mixed the bolts up ?? Both L/H and R/H are the same. Any ideas ?
Thanks.
Joined: 16/04/2014(UTC) Posts: 768 Location: Victoria Thanks: 1 times Was thanked: 49 time(s) in 47 post(s)
Yes, they do that. The bolts are not fully threaded (some may argue that "bolts" are by definition not fully threaded, but "machine screws" are) presumably so the shims, when installed, don't bear on the thread.
Thanks: 1 times Was thanked: 197 time(s) in 180 post(s)
Yes, the way I was taught was that 'normal' bolts are not fully threaded, but those that have threads all the way to the head are called 'set screws'.
These front ends are set up to require shims. If they are all removed you end up with way too much positive camber.
Dr Terry |
2 users thanked Dr Terry for this useful post.
Agree. Standard BHP Apprenticeship training: bolt has a neck or shank, full thread is a set screw. From memory the original distinction has little to do with the presence of a neck/shank though, just the form of the bolt in a bolted connection is far stronger than if a fully threaded fastener was used.. A bolt has a nut, and to fasten it up the bolt stays still and the nut is turned, whereas a (set) screw is turned (screwed) into a thread to fasten it. The thread is normally contained within what is being fastened. Edited by user Wednesday, 8 May 2019 1:51:31 PM(UTC)
| Reason: Spelling |
Joined: 21/04/2017(UTC) Posts: 293 Location: Tolmie Thanks: 2 times Was thanked: 24 time(s) in 24 post(s)
I'd put a couple of shims, say a thick and a thin, on all four bolts. That is nowhere near correct alignment but will get you to the tyre place for a front alignment without damaging the bolts. Probably safer to use old tyres as they will probably scrub out a bit depending on distance.
Thanks: 50 times Was thanked: 6 time(s) in 6 post(s)
I used two shims each bolt on both sides to address the issue you described. At least I knew it was the same and avoids what you have seen. If you don't have the original shims any steering place will have something similar.
There are repros on Ebay in different thicknesses. |
Cheers guys . I have a few shims heading my way.ive had a few weird things going on. You basically have 6 bolts per side. 2 on the upper control arm shaft 2 on the steering arm 2 to connect the calliper.
All are roughly the same length but the 2 steering arm ones need to be longer to accommodate a nut/washer.
Me feels something may have been mixed up when i sent away for plating. Maybe I bagged em up wrong. Confusing the crap out of me.
Hi Devo
Yes they all have the same 7/16" UNF thread, but are different lengths.
My listing says;
Upper arm pivot bolts - 1-5/8" long Caliper mount bolts - 1-3/8" long Steering arm bolts - 2-3/8" long
Dr Terry |
That makes more sense. Thanks
