trowel Offline
#1 Posted : Tuesday, 4 June 2019 3:48:09 PM(UTC)
trowel
do I need a ford 221 crank to stroke 202 motor , and what pistons do I need ? all help would be appreciated thanks
#2 Posted : Tuesday, 4 June 2019 4:36:28 PM(UTC)
Do some Googling, You need a Ford crank but it needs to be cut and shut and other mods. I don't think you do it to a 202 though, you need the smaller mains tunnel from memory so you need a 186 block or maybe a 179. Lots of $ though when you could do it far easier and cheaper with a replacement 6cyl like a VN onwards V6 conversion or a Chev 250 or 292ci 6cyl. Even a late Ford engine. What is it going into?
#3 Posted : Tuesday, 4 June 2019 5:15:28 PM(UTC)
Agreed. The $$$ spent is not worth it. They don't rev that well either.
221 Ford cranks are like hens teeth these days & a lot of machining is required, not to mention the short pistons etc. which may be custom.
If you want to keep the Holden 6-cyl, get a good head & put EFI on it.
If you want some other ideas, have a read here:-
http://www.bur.st/~oljohnno/toc.html
This page was generated in 0.083 seconds.
