andrew stephenson Offline
#1 Posted : Thursday, 5 January 2012 7:49:18 PM(UTC)
andrew stephenson
COULD ANY ONE HELP TO ID A CRANK I THINK IT MAY BE STEEL.
PART NO 742000 STAMPED ON IT THANKS ANDREW
adam PERTH Offline
#2 Posted : Friday, 6 January 2012 12:08:56 AM(UTC)
adam PERTH
dunno about part numbers, but look at the crank snout, if its been ground down from factory its cast, steel ones ahave a thin line.
also hit it with a steel object, if it resonates for a long time with a high pitched frequency its a steel crank.
greenhj Offline
#3 Posted : Friday, 6 January 2012 3:00:56 AM(UTC)
greenhj
Was thanked: 12 time(s) in 10 post(s)
was there ever a steel 308/304 crank?
petaus Offline
#4 Posted : Friday, 6 January 2012 3:54:20 AM(UTC)
petaus
it,s the other way aroun steel has a wide forged line, cast is normally a thin parting line, i think the 308 were nodular cast iron.
castellan Offline
#5 Posted : Friday, 6 January 2012 4:27:22 AM(UTC)
castellan
Well my early E189 18/5/69 308 HP crank rang like a bell with a lighter colour to the HQ 308 crank, the HP rods same colour as the crank and had massive forging lines, don't think the crank was steel but it must be like the 351 crank in the HO as it is supposed to ring as well.
#6 Posted : Friday, 6 January 2012 6:39:56 PM(UTC)
andrew stephenson
#7 Posted : Friday, 6 January 2012 6:47:05 PM(UTC)
andrew stephenson
[quote]Originally posted by andrew stephenson
thanks guys for all your info idid what you said and its STEEL is it worth anything $ i dont need 6 cylinder cranks as my hz 2 ton is a 308 stroked up thanks again ANDY S
adam PERTH Offline
#8 Posted : Sunday, 8 January 2012 1:52:17 AM(UTC)
adam PERTH
yes petaus you are correct i typed it around the wrong way.
castellan Offline
#9 Posted : Monday, 9 January 2012 3:09:51 AM(UTC)
castellan
As far as 308 cranks go don't the red motor in the Group A VK get an heaver crank.
#10 Posted : Sunday, 7 July 2019 9:30:47 PM(UTC)
Was thanked: 26 time(s) in 26 post(s)
no... the GMH ECS No: 90886 ref :VK558 issued 26/2/85
states the crankshaft is.... as per LV2/M21
that is... std LV2 (304 ) engine crank
This page was generated in 0.140 seconds.
