Joined: 30/04/2005(UTC) Posts: 462 Was thanked: 14 time(s) in 13 post(s)
Hi all , I am just working on my VH 6 and I see it has "VR' stencilled on the rocker cover , what does this mean ? Thanks Mark. |
life is good in "Wine & Holden Marlborough " |
Probably just the broadcast sheet code so the correct engine is used at the assembly plant. You’ll find the codes on lots of things originally like gearboxes, shocks, harnesses etc. |
