Thanks: 2 times Was thanked: 2 time(s) in 2 post(s)
Was it only early Adel and Bris Brabham's that didn't use 28 and 811 model numbers. Edited by user Friday, 4 October 2019 9:08:09 PM(UTC)
| Reason: Not specified
Thanks: 2 times Was thanked: 27 time(s) in 26 post(s)
Only '69 model use the code and inconsistently.
So was the Brabham an option fitted to the S and the SL models
Joined: 21/04/2017(UTC) Posts: 293 Location: Tolmie Thanks: 2 times Was thanked: 24 time(s) in 24 post(s)
Sorry to jump in on your post bazza30555 but I found this in the shed and wondering if it's off a Brabham Torana or did Lukey bring out a series of Brabham mufflers?
Thanks: 1 times Was thanked: 197 time(s) in 180 post(s)
Originally Posted by: bazza30555 So was the Brabham an option fitted to the S and the SL models In HB Series 1, the XS5 Brabham option was available for both 82411 S & 82611 SL models. In Series 2 it was effectively a separate model based on the 82411 S model, but some cars use the 82811 identifier. As Warren has said there was no consistency. Dr Terry |
