Thanks: 13 times Was thanked: 27 time(s) in 25 post(s)
Just a WB Statesman bottom end with VN on EFI heads on it.
Thanks: 1 times Was thanked: 197 time(s) in 180 post(s)
Originally Posted by: castellan Just a WB Statesman bottom end with VN on EFI heads on it. I think what HK1837 was getting at was that a normal WB Statesman motor had an 11WT prefix. A WT prefix block would have been out of a 5.0 WB Commercial, which was officially not available. Dr Terry Edited by user Friday, 24 January 2020 2:45:43 PM(UTC)
| Reason: Not specified |
Very unusual motor! Would love to have that for my WB ute.
I was wondering about the stamping being original. |
Joined: 30/04/2005(UTC) Posts: 462 Was thanked: 14 time(s) in 13 post(s)
I would say "no"to the stamping being original . Thanks Mark. |
life is good in "Wine & Holden Marlborough " |
Originally Posted by: justgm I would say "no"to the stamping being original . Thanks Mark. What do you base that on ? They do exist, but they are rare. Dr Terry |
It is a rough stamping but the 5 looks correct. |
From a judging point of view if I had to judge this engine if it were fitted to a WB , I would say it is too rough to be stamped by Holden . Just my point of view. Thanks Mark. |
Joined: 11/09/2016(UTC) Posts: 208 Location: OZ Was thanked: 23 time(s) in 22 post(s)
A restamp for sure. 5 & 7's are not correct. Probably been decked and had the original number re-applied.
Originally Posted by: 8D11PCH2 A restamp for sure. 5 & 7's are not correct. Probably been decked and had the original number re-applied. That was my original thought, but minus the 11 or 12 in front of the WT |
