Joined: 25/01/2020(UTC) Posts: 4 Location: Sans Souci Thanks: 1 times
I've been reading through numerous HQ posts trying to work out a HQ Coupe body number. I've found a HQ Coupe that I'm a bit suspect about. As usual missing tags!
Correct me if I'm wrong, the stamped number on the firewall is a production line number? Was there any information recorded by the factory on the history of the body? Body number stamped is 16420S
I did a PPSR check on the chassis number EHQ29781S. The report associated the chassis to a 1974 Holden Sedan. I can only assume the search data referenced old registration info as it also mentions GOLD in colour and running a 6 cylinder.
Any advice is greatly appreciated Cheers John
Thanks: 1 times Was thanked: 480 time(s) in 458 post(s)
Contact Holden Historical Services. Ben will be able to figure out what the car was mechanically. I’m 99% sure that chassis number doesn’t belong to that firewall number though. And without tags it is not really a car you want to spend dollars on. Edited by user Sunday, 26 January 2020 12:51:04 PM(UTC)
| Reason: Not specified |
I agree 100% HK1837. I sanded part of the body that revealed it being a red car. The PPSR report has the engine number as a 6 cylinder and as mentioned gold in colour. The diff under the back is a 10 bolt which should be associated to a V8 car (I think)
You could option a Salisbury as a heavy duty diff behind all HQ 6cyl (except cab-chassis where Salisbury was standard). But it is a pretty rare option. There were probably more HQ V8 coupes made than 6cyl so more than likely a 253 car. But without tags it is academic anyway, makes no difference what it was originally. |
So, would it be safe to say the state a rolling shell is in without tags is it is pretty useless and cannot be registered?
You can register it, just need a chassis number which could be anything from AHQ to EWB prefix as the number is on the rails. But without tags it’s value as a car will suffer badly so probably not worth restoring as even a replica. Best thing for it is as a modified with non standard stuff like big block, 9” etc. But before you even think about buying it check all its stainless is with it as a full set of stainless for a HQ-HX coupe will set you back over $5000 or more. Doors cost a fortune too, as do regulators and rear screen. If any of that is missing it may not be worth even starting. Edited by user Sunday, 26 January 2020 4:21:28 PM(UTC)
Wise words there HK1837. Thanks heaps for your advice. I'll see what comes with the shell in the way of parts but I'm tending towards giving it the flick!
