8D11PCH2 Offline
#1 Posted : Saturday, 2 May 2020 12:59:17 PM(UTC)
8D11PCH2
Was thanked: 26 time(s) in 24 post(s)
Anyone have the part numbers for HD & HR X2 exhaust manifolds as well as the same for HR 186S?
All help greatly appreciated.
#2 Posted : Saturday, 2 May 2020 1:05:54 PM(UTC)
Will get them for you.
I think the X2 ones are same as XU1 and the 186S ones are the same as GTR (auto choke pipe in one of them).
HD/HR X2:
7428493 front
7428495 rear
HR-HG 186S and LC GTR including XU1:
7433655 front
7430583 rear
LJ XU1 lists a bit different. Uses the 186S rear one but an X2 front one which is what I expected LC to show, but it doesn't. Unless the LC catalogue is in error.
7428493 front
7430583 rear
Edited by user Saturday, 2 May 2020 1:22:35 PM(UTC)  | Reason: Not specified
8D11PCH2 Offline
#3 Posted : Saturday, 2 May 2020 1:40:58 PM(UTC)
8D11PCH2
HD/HR X2:
7428493 front
7428495 rear
7433655 front
7430583 rear
7428493 front
7430583 rear
Thanks for that.
Pretty much exactly what I expected.
LC GTR & XU1 used the same exhaust manifolds.
I've always suspected the LJ XU1 front exhaust manifold was from HD/HR X2. A 742**** part number seemed like it would be mid 60's vintage.
I'm surprised though that HR 186S would have the same rear manifold as HKTG 186S, LC 82911 and LJ XU1.
I thought HR 186S would be the same rear manifold as the X2 RPO.
#4 Posted : Saturday, 2 May 2020 1:57:19 PM(UTC)
The HK-HG 186S is identical to HR other than sump. I don't think much else if anything changed.
I'm not sure what changed in the rear one between X2 and S onwards, there will be some minor reason for the drawing number change. It may well be a revision during HD/HR X2 period rather than a change for 186S, when you see drawing/part number is a couple of 1000 lower than the revised one for the front for 186S. It may just be a change to give more clearance for a nut or something like that.
8D11PCH2 Offline
#5 Posted : Saturday, 2 May 2020 3:14:18 PM(UTC)
8D11PCH2
It is the angle of the rear manifold outlet for connection of the exhaust pipe that is different between X2 and 186S.
I expected the exhaust system on the HR would have remained unchanged between X2 and 186S but changing the rear exhaust manifold for HR 186S meant revisions to the engine pipes were also required.
Edited by user Saturday, 2 May 2020 3:16:26 PM(UTC)  | Reason: Not specified
