Joined: 2/03/2018(UTC) Posts: 104 Thanks: 5 times Was thanked: 4 time(s) in 4 post(s)
G'day Just asking was there a heavy duty engine mount bracket (one that bolts to the block) of 6 cylinder holdens, HQ -on? I have a pair that came off a very ordinary 6 cyl auto HQ sedan, that are 2 plates welded together. I have owned a few of these cars, worked on a heap, & wrecked a lot & haven't noticed any others the same. There is no additional mounts or bolts that you would expect as was on a/con. I have had these for ages & never worked out what they were for, so I'd thought I would ask around
Thanks Ian
Joined: 2/02/2009(UTC) Posts: 562 Location: On a build over WWII airfield. Got the .50 cal cases from my driveway to prove it Thanks: 30 times Was thanked: 8 time(s) in 8 post(s)
I had a HQ Premier, factory air. It was mid 1990s when I pulled the 202 and threw a 350 at it. I don't remember any thing different in the engine mount department. |
Attn camry drivers. The accelerator is the skinny pedal on the right. |
OK, thanks. It's not really important, just something of interest that I had no answer to.
Thanks: 1 times Was thanked: 197 time(s) in 180 post(s)
It might have been an ADR update. GM-H were doing a lot of crash testing & upgrading in those days.
My 1973 LJ Torana has unique engine mounts (the rubber bit) which have a much heftier captive link. They were introduced at the same time the front sheet metal changes, so must be crash related.
These are no longer available, but are interchangeable with the regular HQ-WB, LH-UC & VB-VK mounts.
Dr Terry |
If I was going to guess I would say torana for rally use
Joined: 11/09/2016(UTC) Posts: 208 Location: OZ Was thanked: 23 time(s) in 22 post(s)
Originally Posted by: HK-Q-Z5.0Lfan G'day Just asking was there a heavy duty engine mount bracket (one that bolts to the block) of 6 cylinder holdens, HQ -on? I have a pair that came off a very ordinary 6 cyl auto HQ sedan, that are 2 plates welded together. I have owned a few of these cars, worked on a heap, & wrecked a lot & haven't noticed any others the same. There is no additional mounts or bolts that you would expect as was on a/con. I have had these for ages & never worked out what they were for, so I'd thought I would ask around
Thanks Ian Yes GMH introduced the reinforced engine mount brackets in January 1973 HQ Holden & LJ Torana production. They were std on all 6cyl Holden & Torana from that point on. It was all part of ADR 10B compliance from 1/01/1973.
OK. Good info thanks. Not sure if it's the same as what I was asking about, I had a look at a LX torana, VB com & WB ute (all 6 cyls), + a box of eng mounts, and none have the same brackets. (as the ones im asking about). Will check some more next weekend
Thank you
Can you put up a pic of the mount brackets you are referring to?
Originally Posted by: 8D11PCH2 Can you put up a pic of the mount brackets you are referring to? I haven't got access to the place where these are, maybe in a couple weeks. Also never tried to put up pics, so I will have a go , or email them to someone Thanks
Hi i'm also working on the same project man and in need of heavy duty engine mount bracket, what kind of bracket did you use and can you send a picture
