Joined: 30/04/2005(UTC) Posts: 462 Was thanked: 14 time(s) in 13 post(s)
My VN S1 Calais air cond is not working , I took it to an A/C place and they said we can just put an adaptor on it a fill it with R134a . Is there a proper receiver/drier replacement so I can use the R134a properly ? Thanks Mark. |
life is good in "Wine & Holden Marlborough " |
Thanks: 1 times Was thanked: 197 time(s) in 180 post(s)
Because the VN system doesn't have a "normal" style drier & TX valve, they really don't need to be altered in any way to run R134a gas. Having said that, the VN's weakness was always the condenser. If you fit a parallel flow style condenser from a VP (it is a bolt in fit) your good to go. Fit the two R134a adaptors & regas the system & that's about it. Dr Terry Edited by user Friday, 5 June 2020 7:57:49 AM(UTC)
| Reason: Not specified |
Great information Dr Terry , I will book it in today . Thanks Mark. |
