Thanks: 2 times Was thanked: 2 time(s) in 2 post(s)
Date casting appears to be 8 F 13, I gather this is 13/6/68. Cheers Bazza.
Yes. The a North American casting plants are all different with how they do it including some using I and some not. |
Was the K**** stamped after the engine was completely assembled.
Yes. Same as Holden engines, after assembly and run (on gas) with timing set and marked. Can’t remember if painted first or stamped after paint. Edited by user Saturday, 29 August 2020 3:12:19 PM(UTC)
| Reason: Not specified |
Joined: 6/07/2019(UTC) Posts: 350 Location: bayside Melbourne Thanks: 218 times Was thanked: 26 time(s) in 26 post(s)
Originally Posted by: HK1837 Yes. Same as Holden engines, after assembly and run (on gas) with timing set and marked. Can’t remember if painted first or stamped after paint. Holden blue and black engines (cannot remember with earlier Red but assume the same) were stamped before painting... |
Pretty sure the SBC style engines were the same, the engine plant stamp went on prior to paint IIRC and the GMH VAP stamp went on obviously after paint as they were stamped here. |
Joined: 29/07/2006(UTC) Posts: 763 Location: in the shed
Thanks: 8 times Was thanked: 14 time(s) in 13 post(s)
Build numbers were stamped before paint. They used a 'mask bar' that went over the numbers and the water hose connections to ensure those areas didnt get any paint. This is the only photo I have of it but I've seen one other. Edited by user Monday, 7 September 2020 1:15:55 AM(UTC)
"I would never want to be a member of a group whose symbol was a guy nailed to two pieces of wood" (George Carlin) |
Thanks: 1 times Was thanked: 197 time(s) in 180 post(s)
That looks like a Big Block Chev.
Dr Terry |
Originally Posted by: Dr Terry That looks like a Big Block Chev.
Dr Terry It is, meaning it is the Tonawanda engine plant. |
Dr Terry Yeah its a BB but I guess a SB would have been painted the same way. Its a black and white photo and someone added the orange colour to it just to highlite that masking bar thing. |
