Joined: 6/07/2019(UTC) Posts: 350 Location: bayside Melbourne Thanks: 218 times Was thanked: 26 time(s) in 26 post(s)
Originally Posted by: Balfizar GM 3749084 Retainer / "G" Clip / Scroll clip. I think it is used on :- Commodore Brake pedal/rod as a retainer M20 and M21 linkage retainer TH400 and TH350 linkage retainer LX on some weird interface (pedal to booster rod) Is it used on earlier Holdens and where can you source it?
FYI ... also used on Hurst and MrGasket shifter linkages |
Where'd the original post go? |
Joined: 20/03/2011(UTC) Posts: 132 Was thanked: 16 time(s) in 16 post(s)
Originally Posted by: HK1837 Where'd the original post go? Fail in trying to edit/add photos etc. don't know what happened but delete was best/only option. Also don't know how quoting still brings it up but just lucky I guess.
That explains it! I thought it was weird hence why I asked. |
Joined: 2/03/2018(UTC) Posts: 104 Thanks: 5 times Was thanked: 4 time(s) in 4 post(s)
Originally Posted by: Smitty2 Originally Posted by: Balfizar GM 3749084 Retainer / "G" Clip / Scroll clip. I think it is used on :- Commodore Brake pedal/rod as a retainer M20 and M21 linkage retainer TH400 and TH350 linkage retainer LX on some weird interface (pedal to booster rod) Is it used on earlier Holdens and where can you source it?
FYI ... also used on Hurst and MrGasket shifter linkages Sorry for delay in putting this up, I wanted to check information. 3327302 Hurst pit pack. $40 free post A fair bit cheaper than others here. Sorry I dont know how to add link
