Wolfpax Garage Offline
#1 Posted : Tuesday, 24 November 2020 12:41:48 AM(UTC)
Wolfpax Garage
Hello, does anyone know the trim colour for HT Trim Code: 1187-10C.
The HKTG Garage Offline
#2 Posted : Tuesday, 24 November 2020 6:18:06 AM(UTC)
The HKTG Garage
Hello Wolfpax Garage,
That would be Kingswood. Black with Black Gretyl pattern Castillon Weave inserts.
#3 Posted : Tuesday, 24 November 2020 11:29:25 AM(UTC)
Was thanked: 480 time(s) in 458 post(s)
1187 is Oasis Green paint. Is it definitely a Kingswood or a Belmont? There was some wierdo trims in HT and/or HG with C code trim, can't remember the specifics. From memory it was like HK material in HT trim or something like that. Warren might have more info.
#4 Posted : Tuesday, 24 November 2020 12:58:27 PM(UTC)
The HKTG Garage
After looking into this further I'm wondering if your ID tag says 10G as opposed to 10C. 10 trim is Black. Black trim wasn't available in HT Belmonts. Black however was available in Kingswood. To correct my previous reply, 10G is the trim code for Gretyl Castillon cloth inserts with vinyl in Kingswood
C trim codes appeared as limited factory run in HG Belmonts. The sedans referred to as 186L Belmonts. They had 186, disc brakes and HT Wyvern vinyl door trims and the seats were Wyvern (HT Monaro basket weave) with HK HT Gretyl Castillon cloth inserts.
I'd be interested to know if it is a 'G' rather than a 'C'
#5 Posted : Tuesday, 24 November 2020 1:01:46 PM(UTC)
The HKTG Garage
1187 is Oasis Green paint. Is it definitely a Kingswood or a Belmont? There was some weirdo trims in HT and/or HG with C code trim, can't remember the specifics. From memory it was like HK material in HT trim or something like that. Warren might have more info.
The "D" trims in HT Belmont were a carry over of HK material to use up excess stock. 'C' trims in HG Belmont were a carry over of excess HT material.
#6 Posted : Wednesday, 25 November 2020 11:42:10 AM(UTC)
Wolfpax Garage
You are correct cleaning up the tag further revealed it was a G. Thanks for that information.
 1 user thanked Wolfpax Garage for this useful post.
The HKTG Garage on 25/11/2020(UTC)
This page was generated in 0.083 seconds.
