Thanks: 1 times Was thanked: 244 time(s) in 218 post(s)
A question for our New Zealand buddies.
GMNZ sold the first Vectra (Vectra-A) in NZ from around 1993 to 1997. Then it was replaced with the same Vectra-B (JR series) which we had in Australia.
My question is did GMNZ assign a model series to this car ? I know your second series Camira was uniquely coded JJ, so I thought that they would've used some sort of code for this Vectra.
Can anybody help me with this one.
Dr Terry |
Joined: 30/04/2005(UTC) Posts: 484  ![New Zealand New Zealand]() Was thanked: 16 time(s) in 15 post(s)
I have had a look and it seems Vectra A was just referred to as "Opel Vectra" . I did find a bulletin that said MY92 . Handbooks just say Opel Vectra. Vectra A went to Holden branding in August 1994 and Vectra B arrived April 1996 , which changed to Aussy assembled in July 1999. Hope this helps , Mark. |
life is good in "Wine & Holden Marlborough " |
Originally Posted by: justgm  I have had a look and it seems Vectra A was just referred to as "Opel Vectra" . I did find a bulletin that said MY92 . Handbooks just say Opel Vectra. Vectra A went to Holden branding in August 1994 and Vectra B arrived April 1996 , which changed to Aussy assembled in July 1999. Hope this helps , Mark. Thanks for that justgm. That's how I figured it. It just seems strange that this is the only "Holden" to not have a series code. As I said they even invented the JJ code for your Aska / Camira. The Vectra-B in Australia was called the JR series when it was first released. Then when they went to local assembly (1998) they give it a small refresh & called it the JS series. Dr Terry |
Joined: 4/01/2021(UTC) Posts: 51 ![Russian Federation Russian Federation]() Location: Saint Petersburg Thanks: 16 times Was thanked: 2 time(s) in 2 post(s)
Opel/Holden Vectra NZ 1992-1996 is it Vauxhall spec, not Opel? Edited by user Sunday, 17 January 2021 6:32:31 AM(UTC)
| Reason: Not specified
Originally Posted by: Torana1978  Opel/Holden Vectra NZ 1992-1996 is it Vauxhall spec, not Opel? My understanding is that the Opel Ascona-C & Vauxhall Vectra-A are essentially the same car, however the Opels are LHD & the Vauxhalls are RHD, with a few minor exceptions. So we can assume that all of the NZ & Aust. Vectra are Vauxhall spec. Also I don't believe that Vauxhall have had their own design office since the late 70s & all Vauxhalls since then have been re-badged Opels. Except the Holden Monaros & VE etc. of course. Dr Terry |
Thanks: 1 times Was thanked: 610 time(s) in 577 post(s)
I think you are right Terry. The FE Vauxhall was their last in house design. It was built in India into the 1990’s though but as a diesel. |
Originally Posted by: Dr Terry  My understanding is that the Opel Ascona-C & Vauxhall Vectra-A are essentially the same car, however the Opels are LHD & the Vauxhalls are RHD, with a few minor exceptions. So we can assume that all of the NZ & Aust. Vectra are Vauxhall spec. Opel Ascona C = Vauxhall Cavalier MK2 (J-Body) Opel Vectra A = Vauxhall Cavalier MK3 (2900 Platform) Opel Vectra B/C = Vauxhall Vectra As far as I know, Vauxhall had their own trim levels and options, and probably, New Zealand received Opel-badged Vauxhalls trims and styling (but I'm not sure). Quote:Also I don't believe that Vauxhall have had their own design office since the late 70s & all Vauxhalls since then have been re-badged Opels. Except the Holden Monaros & VE etc. of course.
Dr Terry Yes, you're right, since late 70's Vauxhalls were the British versions of Opel, Isuzu, Suzuki, HSV, Renault, FIAT and PSA. And even Lotus (VX220).
Originally Posted by: Torana1978  Opel Ascona C = Vauxhall Cavalier MK2 (J-Body) Opel Vectra A = Vauxhall Cavalier MK3 (2900 Platform) Opel Vectra B/C = Vauxhall Vectra
Yes, you are correct, my error. Opel Ascona-C was the Cavalier Mk2 (Our Camira) & Opel Vectra-A was still badged Cavalier (Mk 3). It was Vectra-B where Opel, Vauxhall & Holden were all Vectras. Dr Terry |
