Fastlane
Holden Forums
Holden Technical Talk
Holden EH 179 to HK 3 speed crash gearbox id
Joined: 16/01/2021(UTC) Posts: 14 Location: Victotia Thanks: 5 times
Hello, How do you identify what model Holden a 3 speed crash gearbox originally comes from? Are there identifying numbers to look for? Many thanks for your anticipated assistance.
Thanks: 1 times Was thanked: 480 time(s) in 458 post(s)
Good question. Dr Terry will probably know for sure. I’ve thrown every one that I’ve pulled out of a car in the scrap bin so never had any at hand to compare! |
Joined: 6/07/2019(UTC) Posts: 347 Location: bayside Melbourne Thanks: 216 times Was thanked: 26 time(s) in 26 post(s)
Originally Posted by: HK1837 Good question. Dr Terry will probably know for sure. I’ve thrown every one that I’ve pulled out of a car in the scrap bin so never had any at hand to compare! aaagh HK .... you missed out on the joys of rebuilding/recoing one stuck out in the country ( I broke one on the Bruthen- Lakes Entrance rd and the one servo in Lakes Entrance the car got towed to had a kit) or Saturday night... late (down out back of KooWeeRup near Langlang) and you are suddenly missing first gear and don't fancy a tow home (besides the new GF sitting in the front seat would not be impressed) ps... eventually I bit the bullet HT all synchro box (and Column and linkages and bellhousing) in the HD and goodbye crash box rebuilds |
Thanks: 1 times Was thanked: 197 time(s) in 180 post(s)
AFAIK the late EH to HK box was basically the same thru those model series, except for changes to the linkage levers.
The big change was from the EJ & early EH 149 to the lateR one.
The earlier box only had 4 bolts securing it to the bell-housing, the later one had 5 bolts.
Dr Terry |
Thank you for your help.Much appreciated.
Fastlane
Holden Forums
