Thanks Smitty. The 1.1mm gap NGK were cheap, so if I have to replace no great loss.
This car is pretty much untouched mechanically, however probably 25-30 years ago the prior owner fitted a high energy coil and Scorcher ignition plus a 650 vacuum secondary Holley. When it was at the wreckers I got it from it had a weepy head gasket, so they changed the head gaskets and re-fitted a Holden points dizzy, which is the wrong one (off a HT-HJ 253). It always ran well enough for me to move it out of the shed and give it a run up and down my street (Private Road).
However when I got it running the last time it was running like a pig. I bit the bullet, refitted an original choke operator to the manifold and fitted new stainless repro choke pipes. I had an original 7043284 Quadrajet rebuilt a while back and refitted it, plus the correct late HQ - early HJ air cleaner, plus all the right hoses etc. It now starts and idles right, auto choke works like a dream. It will still need fine carby adjustment on a dyno but goes OK. I ordered a new PCV valve for it and a new PCV source filter for the side of the air cleaner. I even found some of the 38mm pre-heat duct for it from the air cleaner intake down to the exhaust manifold stove. It does still have a miss in it under power, but that is probably a combination of dirty plugs, old dizzy and coil. It has relatively new Eagle silicone leads on it.
I was going to fit a VK HEI dizzy to it that Dr Terry has to rebuild for me plus an original WB HEI coil. However I also have a like new correct HT-HJ 308 dizzy, but it needs cap, points, rotor button, condenser etc. I went looking for those and it was going to be well over $100 for it all, but I stumbled across these new Goss replica HEI dizzy, rotor button, cap and coil for $195 from Spark Plugs direct. Same as this:
https://www.ebay.com.au/itm/202488711470I know it is cheap Chinese junk (although the coil says made in USA on it), however this car would be lucky to do 5kM per year so its not going to wear out! With new ignition and the right plugs I'm hoping it runs sweet again. I wouldn't be surprised if the plugs come out all gunked up as it has been over fuelling and blasting thick black carbon mixed with condensation out the exhaust. Since I put the Quadrajet on that has stopped.
There was a nice solid non-original 12V ignition source there for the coil too, added when the aftermarket coil was on it that I didn't realise was there, and last week I accidentally dislodged that and it shorted to the TH400 dipstick and turned itself into melted green insulation and smoke both inside the car and under the bonnet. I have to trace it back to its source under the dash and will replace it rather than try and bridge the wiring at the ignition switch (pink to yellow).
I don't know what advance curve is in this Goss dizzy, but when I get the VK one back from Dr Terry I'll try and get it re-graphed to the same as the original HJ 5.0L one and use it if the Goss one has a non-suitable curve in it. I'll probably pull the cover off the Goss dizzy module too and make sure it has heat sink compound under the module and some light oil on the advance mechanism, but as for a low kM unit that will never really rev or work hard there isn't much else to go wrong in it.
Edited by user Tuesday, 15 June 2021 1:29:26 PM(UTC)
| Reason: Not specified
