Joined: 2/03/2018(UTC) Posts: 104 Thanks: 5 times Was thanked: 4 time(s) in 4 post(s)
G'day I'm enquiring if anyone knows if T5 boxes have interchangable internals at all...
I have a VN sedan & VP ute, both 5.0L manual. I also have a couple EA - EF falcon (6cyl) t5 box's kept in case of some H series modification plan.
Ive been given a t5 out of VN -VR 6 cylinder & I know the clutch fork is worth keeping, but my question is, is any parts out of a 6 cylinder commodore box compatible for spares? Or mix 'n match ratios at all?
Cheers for any advice
Joined: 6/07/2019(UTC) Posts: 351 Location: bayside Melbourne Thanks: 219 times Was thanked: 26 time(s) in 26 post(s)
AFAIK... there are 6 different T5 style transmissions that have been used behind a variety of engines in any number of chassis from a variety of manufacturers (even HDT had one to their specs.. T5G) with different shaft splines, different shifter positions and I know there are different service/repair kits (look to that number on the side) I suspect.. guess, that interchangability of gear ratios may be a tad difficult... Edited by user Monday, 5 July 2021 3:47:56 PM(UTC)
| Reason: Not specified |
