Joined: 17/07/2021(UTC) Posts: 3 Location: West Australia
1st time post here, so thanks for any reply's ..
The problem I have with my 308 is I have coolant coming out the driver side header flange, not ideal. The car is running fine & not getting hot or missing. So how does the coolant get there ?? I'm thinking maybe head gasket, I have'nt given it a compresson test yet. Thought I'd just see what you guys think would cause it to happen..
cheers Jeff
Thanks: 1 times Was thanked: 480 time(s) in 458 post(s)
Do you mean out the exhaust oft between the block and the head? |
it's coming out the exhaust, if it can get in the header from there then it could be the issue.
Thanks: 3 times Was thanked: 33 time(s) in 32 post(s)
If its coming out of the port into the header than the port wall in the head is stuffed. New head needed
Well it will be a week or 2 before I will have time to take it apart & check it out.. I'll let you know what I find ..
Hi Is it possible that it’s coming past the thread on a manifold bolt. Normally the holes are blind but it’s easy to punch through if drilling out a broken bolt. Cheers
