AC Offline
#1 Posted : Sunday, 10 July 2022 8:47:37 PM(UTC)
AC
I am in the process of making new door cards for my HQ ute. The cards I had were not originals and in poor condition. I have new inner seals. The old ones were riveted in place. The vinyl from the door card ran between the metal trim tops and the seal.
Are rivets the correct fasteners or was a different method used from the factory? Any help will be greatly appreciated.
202tonner Offline
#2 Posted : Sunday, 10 July 2022 9:31:29 PM(UTC)
202tonner
Originals were stapled, I think, with heavy duty staples. These were very low profile.
You can replace them with rivets but check the placement of the rivets. If you put the rivets in the wrong place the card won't slip over the door. Because the top of the door isn't straight there are gaps where the rivets will fit down onto the door. In other places the card is hard up against the door and there is no room for the rivet.
 1 user thanked 202tonner for this useful post.
AC on 10/07/2022(UTC)
8D11PCH2 Offline
#3 Posted : Sunday, 10 July 2022 9:34:11 PM(UTC)
8D11PCH2
Was thanked: 23 time(s) in 22 post(s)
GMH used staples to affix the inner belt strips to the metal trim tops.
Rivets are a common and simple alternative to getting your hands on an air stapler and suitable size staples to punch through the belt strip and the metal trim top.
From memory the metal tops were also stapled to the trim board.
Edited by user Sunday, 10 July 2022 9:35:56 PM(UTC)  | Reason: Not specified
 1 user thanked 8D11PCH2 for this useful post.
AC Offline
#4 Posted : Sunday, 10 July 2022 10:01:54 PM(UTC)
AC
Thanks very much for the useful information. Your quick feedback is valued. I have access to both tools and will work out the best way forward.
