Hi team. I need some help. I have brought a reproduction rev-counter for my Monaro off Ebay. Part number is HDMNA-67160 .The seller stated that you must be careful not too wire up incorrectly as damage will result. But then they don't supply a wiring diagram. I have emailed him several times will no reply.
My question is has anyone used one of the gauges and knows the correct way to wire? it. I am using a output from my Msd 6AL box as the trigger. Back of gauge has 4 wires.
Green is earth Grey is illumination (dash lights) Pink ? Brown ?
Any help would be greatly appreciated Thanks
Pink is 12V Ignition & brown is the ignition trigger which usually goes to the coil negative, but in your case use the MSD trigger.
Dr Terry |
