Joined: 22/08/2020(UTC) Posts: 32 Location: Sydney Thanks: 7 times Was thanked: 1 time(s) in 1 post(s)
The conrod bearings on the 253 I'm rebuilding are stamped:
Holden R5J RM50U
Does anyone know if these are standard or oversize ? Rgds.
Thanks: 1 times Was thanked: 485 time(s) in 463 post(s)
They should have a 3 digit number on them if they are under size, like 001, 010, 020 etc. I reckon they will be STD. A simple measure of the journal will tell. |
Thanks HK. No 3 digit numbers on them. I suspect they are standard. Pistons are standard. I would measure the journal but cannot find a spec in the manual. Any idea what it should be ? Rgds.
Joined: 6/07/2019(UTC) Posts: 356 Location: bayside Melbourne Thanks: 222 times Was thanked: 27 time(s) in 27 post(s)
Originally Posted by: HQ_SS_Andy Thanks HK. No 3 digit numbers on them. I suspect they are standard. Pistons are standard. I would measure the journal but cannot find a spec in the manual. Any idea what it should be ? Rgds. my Holden engine manual says - Connecting rod journal diameter 2.124 - 2.125" out of round .005" MAX Bearing clearance .0007 - .0022" HTH |
