Joined: 28/03/2022(UTC) Posts: 4 Location: Gold coast
Hi All,
My GTS badges on the guards are about an inch back from the normal position and I have seen others with the badges back.
Did any factory at any time locate these badges differently?
Mine is a Nov 68 Sydney HK
Rob
Are they HK guards on it? |
I think so Do HK have holes on the lower bolts and HT have slots?
HK have a drain hole in the bottom, HT-HG have a slot. In between the bottom bolts. |
I guess the real question is which is correct for my car before I paint it
I was thinking the guards may have been replaced and the badge holes redrilled. |
Yeah you can see where the orig holes were . They have been brased up and new ones drilled But Why? Did someone believe that was the correct position for that car or maybe just personal choice? If personal choice its funnu there seems to be a few of them out there. Maybe it was a thing back in the day Anyway I think mine should be moved back forward to line up with the flute Would you agree?
