Thanks: 11 times Was thanked: 11 time(s) in 9 post(s)
What would be the best coil to used in a hq with a 350 chev the motor is stock,
a bosch GT40 or a GT40R or something else.
Originally Posted by: LS350 What would be the best coil to used in a hq with a 350 chev the motor is stock,
If the car has its stock wiring harness the GT40R is the one. GT40 is designed for earlier cars without a ballast resistor. Dr Terry |
Goss have them too, C173. Unfortunately they are red like the GT coils https://www.goss.com.au/catalogue/
They are only about $35 on Ebay. For some reason they make the HEI ones (with post or socket) in black. |
If you want an original look, you can use a Bosch SU12R which has the silver case. My p/no. for those is IGC-300.
Dr Terry |
Thank you Dr Terry and HK 1837 for your help
