#1 Posted : Friday, 12 May 2023 6:23:37 AM(UTC)
The engine light is on in my sons VE V6 Ute. Apparently it’s the timing chain causing the code.
I am considering doing it myself, the price on the kits seems to vary a lot. Any advice on which kit to use?
8D11PCH2 Offline
#2 Posted : Friday, 12 May 2023 7:02:15 AM(UTC)
8D11PCH2
Was thanked: 23 time(s) in 22 post(s)
Before rushing into changing the timing chains I would check that it isn't a faulty cam position sensor or a blocked cam actuator causing the engine light.
#3 Posted : Friday, 12 May 2023 7:05:39 AM(UTC)
I guess you have to pull the timing case off to check that? It’s got around 200000km on it.
8D11PCH2 Offline
#4 Posted : Friday, 12 May 2023 6:29:56 PM(UTC)
8D11PCH2
Not at all. The cam position sensors and actuators are visible and easily removed from the front of the engine.
Good time to replace their oil seals in the timing case if you are removing them for inspection.
#5 Posted : Monday, 15 May 2023 6:19:08 PM(UTC)
How do you check these sensors?
KeithA Offline
#6 Posted : Tuesday, 16 May 2023 4:33:12 PM(UTC)
KeithA
I believe you are right and it's the timing chain wbute. Mate chased a code for quite a while through service departments and mechanics and most said it was the chain. He didn't believe it until about a month or so ago, he relented and got it changed. He say's the car goes a whole lot better now without any code being thrown.
