Fastlane
Holden Forums
Holden Technical Talk
HZ sedan banjo diff rear sway bar
Will a hz banjo rear sway bar fit a Salisbury v8 10 bolt diff in a hz? I have found a banjo diff with rear sway bar and want to fit it to my Salisbury diff.
Joined: 30/04/2005(UTC) Posts: 463 Was thanked: 14 time(s) in 13 post(s)
6 cly bar is 9946483 and V8 bar is 9947541 , but could just be a diameter difference ? |
life is good in "Wine & Holden Marlborough " |
Joined: 6/07/2019(UTC) Posts: 356 Location: bayside Melbourne Thanks: 222 times Was thanked: 27 time(s) in 27 post(s)
Originally Posted by: Mav Will a hz banjo rear sway bar fit a Salisbury v8 10 bolt diff in a hz? I have found a banjo diff with rear sway bar and want to fit it to my Salisbury diff. tape measure jobbie... measure the distance between the brackets... if the banjo and Salisbury distances are the same then the only other issue is the insulator as the V8 one is thicker |
Originally Posted by: Smitty2 Originally Posted by: Mav Will a hz banjo rear sway bar fit a Salisbury v8 10 bolt diff in a hz? I have found a banjo diff with rear sway bar and want to fit it to my Salisbury diff. tape measure jobbie... measure the distance between the brackets... if the banjo and Salisbury distances are the same then the only other issue is the insulator as the V8 one is thicker What about a different shape (larger loop ?) because of the larger diff bulge ? I'm not sure, just asking. Dr Terry |
Thanks: 1 times Was thanked: 485 time(s) in 463 post(s)
6cyl 1s 14mm. V8 is 16mm. |
Originally Posted by: Dr Terry Originally Posted by: Smitty2 Originally Posted by: Mav Will a hz banjo rear sway bar fit a Salisbury v8 10 bolt diff in a hz? I have found a banjo diff with rear sway bar and want to fit it to my Salisbury diff. tape measure jobbie... measure the distance between the brackets... if the banjo and Salisbury distances are the same then the only other issue is the insulator as the V8 one is thicker What about a different shape (larger loop ?) because of the larger diff bulge ? I'm not sure, just asking. Dr Terry Holden used the same shape bar on Commodores and also on WB I recall .. with both the small and large Salisbury diff cenrtres which have rather different diff covers.. but still not 100% on this Edited by user Wednesday, 24 May 2023 9:01:16 PM(UTC)
| Reason: Not specified |
Fastlane
Holden Forums
