Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
Could an issue with the coil cause the tacho not to work in a wb v8? I’ve checked the wiring and had the tacho checked
Joined: 6/07/2019(UTC) Posts: 355 Location: bayside Melbourne Thanks: 220 times Was thanked: 26 time(s) in 26 post(s)
Originally Posted by: holden05 Could an issue with the coil cause the tacho not to work in a wb v8? I’ve checked the wiring and had the tacho checked if the coil is the correct type (for HEI ignition) and the engine starts and runs fine... then probably NOT the coil I reckon |
Yes, starts and runs fine. I’m outta ideas on what it could be
