Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
I’m trying to id the dash in the wb ute It’s a gts style with a woodgrain fascia and yellow needles I’ve been told it’s a hz premier dash Would this be correct?
Yellow needles is WB or HZ. Woodgrain fascia could be later HJ to HZ Premier or later HJ LS or HZ SL/E or HX LE. The SL/E and LE have a burr walnut finish. It is possible the sports instruments are original to the WB and it has had the fascia replaced, or they could be out of another HZ or WB. Does the fascia have an RTS badge on it? |
Means HZ, so it’s either HZ Premier or HZ SL/E. They are different wood grain to each other. |
yep. looks like its a hz premier. does anyone have a wiring diagram for this?
I do. Can I email it to you?
