Fastlane
Holden Forums
Holden Technical Talk
Holden Statesman WH v6 battery change and codes
Joined: 24/10/2023(UTC) Posts: 2 Location: NSW Thanks: 1 times
Hi there, I changed the battery on my 1999 WH Statesman and car runs as normal but its asking me to input the codes on the dash panel. Were do I find these codes?
Originally Posted by: HW Hi there, I changed the battery on my 1999 WH Statesman and car runs as normal but its asking me to input the codes on the dash panel. Were do I find these codes?
I assume you are asking about the radio code. If you don't have it, look in your owners manual folder for the card with that info, failing that ask a Holden dealer. Last chance, if you still don't have, find someone with a good scanner (G-Scan, Tech2 or similar) & check in the body computer, it should be recorded in there. Dr Terry |
Fastlane
Holden Forums
