Joined: 22/08/2020(UTC) Posts: 32 Location: Sydney Thanks: 7 times Was thanked: 1 time(s) in 1 post(s)
Hi All. Should there be a gasket between the M20/M21 gearbox and the bellhousing ? Doesn't seem to be one in the manual. From memory my EH crashbox has one, so not sure if it's the same on the 4 speeds.
Rgds.
Thanks: 1 times Was thanked: 487 time(s) in 464 post(s)
No, they just bolt up. There is a seal (or scroll on the early ones) on the clutch gear/shaft. |
